MFL
Jan 14, 2024Nomad II
While some types of RV anti-freeze are better than others, most will turn to slush or freeze at extreme temps. It should not expand, cause any damage. I normally open low point drains, after using anti-freeze in Fall, and blow most out. It will be mostly pure, so I dump the small bucket of used AF down the toilet, to keep some liquid in black tank.
You should be fine come Spring, when you flush your system.
About Truck Camper Group
271 PostsLatest Activity: Feb 06, 2026
