silversand's avatar
silversand
Anyone had experience with Bluetti lion power stations?
Anyone here have experience porting around a Bluetti AC200 (P) lithium-ion power station bumping around in the truck camper environment ?
We are looking at acquiring one. These, built with LG Chem's 3C pouch cells (that alone is phenomenal).
What we like about the "spec", is that the unit has dual independent MPPT controllers built in; can "handle" up to 150 volts incoming from a solar array (say, 700 watt array). Charge time from 10% to full under optimum in something like 2.7 to 3.3 hours flat. Working temp from 0C up to +40C. Charging low temperature protection (but we never expect its charging environment to ever be below 7C -ish....ever). 5 ways to charge it. 2000 watt pure sinewave (inverted to AC) continuous load at 1800 to 1900 watt draw. And, the interesting part, an aircraft twist connect 12V DC 25A output (I can connect to our truck camper 12V DC mains). I've seen an AC200P power up an air conditioner (7000btu) in a good reputable review.
I was toying around with building my own lithium-ion batteries (a pack of 3.2V LiFePO4 units strapped together), but once you add up the home-made LiFePO4 (in the $700 CAD range), and 2000watt pure sinewave, and the 2x MPPT controllers and AC power brick and the array of 7 cables, and sockets to add into drilled holes in a battery box....and, a touch-screen display....holy crow....WAY more expensive than a Bluetti 2000Wh unit. Worse, if I buy all the separate parts, I'll essentially have no warranty. The Bluetti, has a 2 year warranty (with possibility to acquire a 3 year warranty if I buy during a deal event).
