- mellowExplorer
cooldavidt wrote:
Hey Mallow
What did you actually see? A broken Brophy or it popped out of the hole?
If the latter it was not installed properly
It was ripped out of the hole, you can't really expect a truck bed to take that kind of force time and again, especially modern truck beds. I would recommend a belly bar and bumper buttons over Brophy ANY day. - mkirschNomad IIHow many tens of thousands do you have in the truck? How many tens of thousands do you have in the camper? I just don't see any rational reason to pinch pennies on the tiedowns. $600 is chump change. Your time is worth something. Raw materials are not cheap.
I bought the Torklift fronts for my $2000 camper and have not regretted it for a minute. - cooldavidtExplorerHey Mallow
If the latter it was not installed properly - cooldavidtExplorerhttps://www.crbrophy.com/tdhd.html
- mellowExplorerIf doing any 4x4 I would not recommend Brophy, I have seen them rip out in the past.
Honest review on Brophy: https://roamlab.com/brophy-camper-tie-downs/
In the end it will mess up your bed as it can't take that stress from offroading.
Edit: Added Link - cooldavidtExplorerBrophy works well.
https://rvpartshop.ca/product/truck-camper-tie-downs/34563-brophy-set-of-4-camper-tie-downs-zinc-tdbp.html?nosto=searchpage-nosto-1-ca
Cheapest is chain and a turnbuckle - mellowExplorerLook up belly bar. You can make them pretty easily, it will get you started till you figure out if you want to upgrade to better mounts for the front. As mentioned the back is easy with bumper buttons or building off the hitch.
Also check out happijac, you can find them used from time to time and it is a good system on older trucks (you don't have your year in signature). - Kayteg1Explorer IIFor front $300 is good price, but for the rear I build my own.
Using some junk I already had, I bought $10 worth of material and slightly over 1 hr of labor/welding.
Posted the pictures several times already.
About Truck Camper Group
263 PostsLatest Activity: Nov 13, 2025
