bid_time
Sep 10, 2025Navigator
It is absolutely necessary if you are going to cover your RV that the cover is “breathable”. Research it! Lacking that, a dehumidifier should suffice if used properly. It should be sized per the size of the space to be dehumidified and how often you plan on emptying it.
stevenal
Sep 13, 2025Nomad III
Count me as another Oregonian who wouldn't dream of covering my camper with something waterproof and vapor- proof.
Check the temperature rating on any dehumidifier you look at. Compressor styles might require running heat to be effective. Desiccant styles can handle much lower temperature.
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
