ahh, it probably just died, it wouldn't be because of the LiFePO4, they don't draw power they accept power like any other battery. they just do it more efficiently.
a 3000 watt, wow are you running the microwave and the toaster at the same time? I just run a 2000 watt in my 5th wheel, I couldn't imagine what I would do with a 3000 watt inverter haha. I am looking at the renogy 2000 watt inverter/charger for my truck camper. just haven't decided for sure if I want to put an inverter in it yet. if I do THIS is the one I am looking at.
The Victron Displays a warning message about if an external charging source with a higher operating voltage is applied to the circuit, the Victron will shut down and go into a safety more from which you need to disconnect the battery and solar from the MPPT controller and remove the over voltage device before the system will restore.
