anutami
Aug 23, 2020Explorer III
deltabravo wrote:
I am not terribly convinced that Northwood would use a 1/4 piece of plywood as the floor material. That thin of wood won't support much weight at all.
I do have access to the basement from the cabover step
Basically they have the flooring laid on top of a 1/4” piece of something then block styrofoam with another piece of 1/4” something (not sure if I would call it plywood) supported by the aluminum trusses spaced every 3 feet I believe.
It appears to be the same type of construction in the roof heres a pic of the roof when I removed the vent and installed some fans
And here is where the soft spot is
About Truck Camper Group
300 PostsLatest Activity: Aug 21, 2026
