AnEv942
Aug 23, 2020Nomad
anutami wrote:
Pretty sure the top layer of 1/4" luan has weakened and its pushing into the foam layer. The underside luan portion is holding strong. I think the only way to tackle this is from the top side...
I agree with addressing from the top. Adding support under top floor sheet would work IF you removed bottom luan, cut channels in the bonded foam to insert stringers to under side of floor. Adding supports under the bottom luan sheet wouldn't do much as its the foam that's allowing top sheet to flex...1/4"? what were they thinking. No internal structure, just external frame looking at linked diagram-wow.
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
