emcvay's avatar
emcvay
Explorer III
May 05, 2025
Truck Tailgate removal and storage
Curious, has anyone seen a lift or similar item used to remove a tailgate and store it?
I have a bad back and can no longer lift my tailgate to remove it or replace it.  Curious if there is any sort of device that would aid in doing that?
Thanks!
  • I can easily carry my 2000 F-250 tailgate, but the 2006 tailgate is at least double the weight. I was able to get the tailgate off the truck, but I wasn't going to carry it into the garage. I do have a spare hand truck and I set the tailgate on that with pad on the bottom to protect the edge paint of the tailgate. I then took a cargo strap, and strapped the tailgate to the hand truck. I wheeled it into the garage, and there it sits, tethered to the wall, nice and safe till I need it again.
  • I have a small 12V winch rigged up in the shop I  can use to unload stuff out of the truck.  I use it for the 5th wheel hitch right now, but with a couple straps I can see why it wouldn't work for a tail gate.  that was an expanded idea for it when I got older.  With my ford I would never leave the tailgate on with a camper as one has suggested, they are just to darn heavy and not flat.  I can get mine off right now but I can see in 5 or 10 years having to feed a couple straps through it, then unhooking one side, taking  the weight off with the hoist then pulling it out of the other side.  then its all hoist.
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    There are long brackets off of the Fox bumper that will interfere with the tailgate on most trucks.
  • emcvay's avatar
    emcvay
    Explorer III
    Maybe the toad interferes?  I'll take a closer look.
  • emcvay's avatar
    emcvay
    Explorer III
    For some reason I thought the AF990 needed it removed.  If I didn't have to remove it and I've been doing it all this time I need to kick myself! lol
  • But you have an AF camper iirc.
    every AF I’ve seen is flat on the bottom, the rear overhang is at the same level.
    Just leave the tailgate on. I ran for years with the tailgate on. It doesn’t damage the tailgate nor the camper. Drove it to AK and didn’t even have rock chips in the paint.
    Only reason I removed it at all was the 2nd AF camper we bought, I built a shelf/rack for the generator which interfered with the tailgate.
  • Never seen one. But I’m sure you could rig something from the rafters. Tie box knot around the tailgate and pick it up from that.
    Or offer a neighbor a couple cod beers for 30sec worth of work.
    • valhalla360's avatar
      valhalla360
      Navigator
      Give me a "cod beer" and I'm liable to take a hammer to the tailgate.
      But seriously, it wouldn't be hard to add 2-3 eyebolts and use a simple pully on the garage ceiling to lift it.
