I added to heated LiFePo4's to mine (Vaterer 100AH batts) and a new DC Converter to handle LiFePo4's. My next project is to remove the little 50w solar panel and upgrade to a 200w flexible BougeRV panel (That I'm testing for them) and a new 40a CC to go along with it.
I've also got a 4kwh battery and Redodo 45amp DC to DC Charger (with 600w solar MPPT controller built in as well) that I'm planning on installing in the truck and feeding back to the box just in front of the wheel well. This will be a bit tricky so I'm not 100% certain I'm going to do it but if done right I'll really just need to run wires to the alternator and battery in the engine bay, install the charger under the wing of the camper and plug it into the aux solar input and then place the battery in a secure box in front of the wheel well.
This would give me the ability to charge the extra battery by switching cables and/or charge the camper batteries when needed off this 4kwh battery. It's something I've been playing with.
I've also received a new 400w foldable solar panel and have a second coming that I plan to test with a CC under the wing of the camper by the aux solar input so I can add 400-800w of solar while stationary (let's be honest, more like 300-600w since foldable panels rarely get angled right and their bends limit their ability to produce).
Lastly, I've been toying with the idea of switch to a 12v AC unit but it's a 10k BTU unit vs the 13.5k BTU's I have now and since we're in the desert I'm not sure I want to step down like that.
