- BarneySExplorer IIIMoved to Roads and Routes from 5th wheel forum.
- IvylogExplorer IIIIt's a US highway so semi's use it BUT Berthound pass is 11,300' so your DuraMAX is going to be maxed out...doable but slow going as you will probably start losing power once you get above 10,000'. Lots of switchbacks but most of it is 3 lanes...2 on the uphill. Well worth doing as we LOVE Grand Lake over TT (tourist trap) Estes Park.
Manually select a gear that keeps your rpms up and will keep it from up-shifting when you go into a curve. Same thing going down and there are pullouts if you have traffic behind you. - naturistNomadWait, isn't a DuraMAX a turbocharged diesel? If so, it will suffer no power loss going over 10,000 feet.
- Bionic_ManExplorerIt is a nice drive. We go that way frequently towing a 5er and boat tandem.
If you are going east on a Sunday afternoon, be prepared for a lot of traffic. - BusskipperExplorer
SDM wrote:
How is the highway 40 from I-70 to Grand Lake. Mountain passes and curves?
Beautiful drive and Great Road.
Has Curves and Berthoud Pass is a real one.
Options are to do Trail Ridge through RMNP - on RT 34 - Narrow Curvy and again Beautiful Drive if you go early you will miss most of the traffic, and if you go late Good Luck:)
One more option is the I-70 to Silverthorne, using Eisenhower tunnel, then taking RT 9 North to Kremmling then on up to Grand Lake.
Again Beautiful - easy - as you did the Mountains on I-70 - is the route recommended to those who prefer the easy route to drive and need/want to avoid the Passes.
So there you go, three options, all, because they are in Colorado, are just Beautiful Drives, so take your Pick or drive all three, which would be my Recommendation, then let us know what you thought about each.
Best of Luck, - Thom02099Explorer II
Mountain Pass? Check
Curves? Check
It is not overly difficult however. It's 3 lanes all the way -- 2 lanes climbing on both sides. Four switchbacks on your way up, a parking area at the top of the pass where one can park and hike even higher and have some fantastic photo ops.
Of note on the downhill side north of the pass, there's a couple of switchbacks and then a fairly long downhill that's not so curvy. Don't be fooled by that! Toward the bottom there's a couple more switchbacks and they sort of sneak up on you if you're not paying attention. Past those last couple of switchbacks and then it really is rather smooth sailing in to Winter Park.
And a Duramax should be fine at 11,3. I was up over 12K with mine a few weeks back and it hardly noticed the elevation change. Sure as heck was a lot better than doing the same thing with a gasser Tahoe! - SDMExplorerThanks for help. Have been over Monarch pass with no problems. Just checking on 40 highway.
- BusdriverExplorer IIJust came from Grand Lake , towing with a duramax the climb going & coming no problem, jus take your time the road over the pass is in great shape, we stayed at the winding river Resort, it is not a resort , but a nice campground. While you are there be sure to eat at Fat Cat Cafe Awesome Breakfast Buffet.
About Bucket List Trips
13,487 PostsLatest Activity: Jan 18, 2025
