CA Hwy 89 Monitor Pass
lanerd
A friend of mine is planning on taking his 35' gasser motor home (plus toad) across Monitor Pass (east to west). Is this advisable? Anybody done this before?
thanks
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
7 REPLIES 7
lanerd
Thanks for all the suggestions. I've passed them on to him and he's decided to go on up to Hwy 50 and go across that way.
Again, thanks
Ron
Ron & Sandie
TPMS: Pressure Pro
newlee
I have taken this route. As I recall there were more bicycles than cars on the road. I had no problem.
But I don't plan to take it again.
Dan & Pat Newhall
Central California
2003 Newmar Kountry Star DP 3353
2001 Jeep Grand Cherokee Toad
1995 Ford Ranger STX 4X4 Toad
1995 Jeep Wrangler Toad (KISA RCK}
2gypsies1
nevadanick wrote:
The road is not that tight. As long as they are comfortable with mtn grades there is no other issue. If they want to avoid the pass then go to Gardnerville and take Centerville rd across to 88. Tell em to take a left at the 7/11.
This is what we've always done. No issues for any size RV.
Full-Timed for 16 Years
.... Back in S&B Again
nevadanick
bbaker2001
that will be a long rig for that road.
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
Tiger4x4RV
X2 on that. Just because you can doesn't mean that you should.
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
jmtandem
I am sure people have done it before. If this helps it is a great motorcycle road. Lots of curves, lots of climbing and lots of descending. A diesel with an exhaust brake makes the descent lots easier. A gasser that can only be downshifted for engine braking downhill will be interesting. It can be easy to run out of service brakes before you run out of hill if not careful. For a few extra miles and mostly flat your friend could go to Minden/Gardnerville on US 395 then take SR 88. Probably lots easier for a motorhome. Can it be done? Sure. Does your friend want to?
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
