Hwy 166 from Bakersfield to Santa Maria while towing?
TOOBOLD
We've never taken HWY 166 to the coast. We have a F350 CC, LB and a 34' 5th wheel. Does anyone know how long the climb is out of Maricopa and the grade? Most important is it doable with our combo? I'm concerned of switchbacks as I have one kiddo that gets car sick.
3 REPLIES 3
aerbus32
Did it a number of times in our previous rig. 32' gas towing a Grand Cherokee. You won't have any trouble. I would try to avoid using it Fri or Sunday. It probably gets a fair amount of weekend traffic over to Pismo.
shakyjay
Although I have driven 166 many times I have never driven it while towing. Actually just drove it a week ago and the road is good. I wish I could tell you what the grade for Grocer Grade is coming out of Maricopa. Best I can do is tell you that as you leave Maricopa it starts out very gradually for a few miles and then gets pretty steep for a couple more miles (just guessing at the distance). Most of the steep section has two lanes so traveling slow is not a problem. The down side into Cuyama Valley is a lot more gradual so no real problem. There are a couple of curves but no switchbacks up over the grade. Through Cuyama Valley is basically straight and two lanes but a good road. As dicknellen pointed out there is a park in New Cuyama on the south side of the road. Plenty of room to pull off under shade trees along the road to take a break if you want. As you get to east end of the valley it gets a little curvy but no real switchbacks. Mostly fairly gentle curves. There are a couple of very short and mild climbs up and over to 101. The route is traveled frequently by both trucks and RVs so it is very doable. Just a word of caution the CHP as well as respective county sheriffs do patrol and ticket speeders. Maricopa is not as bad as it once was (they got into a bit of trouble) but can still be a speed trap area.
2007 Rockwood 8315SS
2004 GMC 2500HD Crew Cab Duramax Diesel
1999 Dodge 1500 5.9L Gas
dicknellen
When we lived in Bkfd for 20 years this was our route to the coast, MH w/toad, PU with 5th wheel also with trailer no problems. Always took a rest break in New Cuyama, usually near the park under the shade trees. There are some curvy sections and a long grade coming out of Maricopa. The grade is steep, just get down in low and take it easy. Dick
