RV rental in Alaska
KampingKris
We are thinking about flying to Alaska and renting a small class C for two weeks. I know it will be pricey, but so would be driving the bus at 7 mpg round trip 5000 miles or so. And we figure we can get into other state/forest campgrounds that the bus wouldn't be able to fit.
And then there's the issue of mechanical breakdowns... After being towed in Oregon... we are gun shy. And frankly, not all that mechanical. Although in the two years of bus ownership, we are much more educated on our diesel.
Anyway... the question is - anyone done this? Is there a rental company to stay away from?
KampingKris & FiremanSteve
Jada - American Eskie princess
2008 Tiffin Allergro Bus
2010 Polaris 850XP
2010 Polaris RZR
23 REPLIES 23
Turner__P
We did this about 8 years ago. came home and traded the trailer for a Class C. We did 2 weeks and would have done more if we had the time. Note that Alaska closes right after Labor Day. We did the first 2 weeks in September and it was great but some attractions were closed already. We would do it again. I want to drive from SC to Fairbanks and back but that is a lot of wear and tear on my unit so I am still debating. Good luck on your trip.
Paul T
GMandJM
Glad to see this thread.
Just curious: How long of a time did you all rent when you did Alaska in a C? What's a reasonable span of time for a first-time visitor who plans on going back "someday"?
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
pegdiver
I would rent from Great Alaskan Highways again in a second! They were great on our 2 rentals. Had to have 1 repair done - part flown in, guy was fixing the toilet while we were food shopping. All within 24 hours. Very prompt calls from them and follow-ups. Easy to deal with.
2012 Winnebago Adventurer 37F with 2012 Jeep Liberty toad.
Old - 1999 32' Adventurer (no slides) with Grand Vitara toad (105,000 miles!)
Pride 3 wheel mobility scooter
Only 3 states to go in the USA, Camped in most of Canada and 4 states in Mexico too!
PA12DRVR
So, a couple of thoughts....
- As mentioned, GAH and ABC seem to have a pretty good rep; I rented from AB years ago and it was a good experience (it was long enough ago that they were only AB then, not yet ABC ๐Ÿ™‚ ) and while I've never rented from GAH, I hear nothing but good about them.
- As a more-or-less lifelong Alaskan, if you only have two weeks, I'd suggest (anathema, I realize) flying to Anchorage, renting a car, and using B&B's for your two weeks.
- Alternatively, as suggested, take the AMHS ("Ferry") from Bellingham up the Inside Passage. I would suggest some effort to identify stops on the way. One can take the Ferry from Bellingham "straight through" to Whittier (near Los Anchorage) in the summer, but it's a lot of time on the boat...better to maybe take the ferry partway up, spend some time, and then catch the ferry back down?
- If taking the ferry, I'd again recommend no motorhome, just yourselves: do B&B's or motels wherever you stop and rent a car if need be.
CRL
My RV is a 1946 PA-12
Back in the GWN
lakeside013104
Great Alaska Holidays. Pricey, but a professional outfit. Other companies may be less money up front, but they hit you with all sorts of fees and service charges when you return the RV.
Have a safe and enjoyable trip.
Lakeside
noplace2
2gypsies wrote:
First, you might consider taking the Alaskan Ferry from Bellington, WA
First, just for clarity, that's Bellingham, WA.
Second, I agree with the sentiments already expressed. We spent an entire summer in AK. We hauled our rig and the experience through BC and the Yukon was worth way more than the price of admission. ๐Ÿ™‚
If I'm reading correctly that you only have 2 weeks, by all means don't even think about taking your RV. We left the states from N Washington and it took us 4 weeks just to get to AK. Even doing the ferry thing, you'll still have only a week left.
AK is worlds away from anything you've likely ever experienced. My unsolicited advice? Wait until you have the time to do it right.
In direct response to your original query, do NOT think about renting an RV in Skagway unless you have unlimited funds. Whitehorse, YT would be a better choice, although still pricey. NOTHING in AK and the surrounding area is inexpensive.
โ€˜Love is whatโ€™s in the room with you if you stop opening presents and listen.โ€™ - Elain - age 8
D_E_Bishop
We have rented from both ABC and Great Alaskan Holidays, the rental from ABC was before we had an RV and long story but the DD's and DW wanted to go to Dutch and I wanted to go fishing and then a week in the RV. At that time is was extra for everything except the basic linens and towels and meager kitchen equipment.
A couple of years ago we took the DGKs for three weeks because driving would have taken up all our time. For that trip we went with GAH and could not have been happier. Well stocked with linens and towels and plates and silverware. New 31 foot Winnie Class C. Same thing as noted by someone else, the flights are almost all late night so they left a key for us and the beds were made. Check in and out were easy. Only problem is any left over food has to go in the trash unless someone checking in wants it.
We were interested in going to the ARCTIC Circle and that was permissible and even up to the town above the circle. By the way on the Summer Soltice the sun is visible above the horizon from the BLM campground a mile north of the circle.
I would recommend GAH to anyone they are great. By the by, they do run specials so check them out before you rent.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
tonymull
I've rented from ABC a few times in the past. Good company. You can rent motorhomes or you can rent truck campers. Last time I did that was 2003. I got in on a red eye took a cab to ABC and they had left the camper open for me to sleep in till I could check it out and take off in the morning...no charge. Their rigs are completely outfitted, just bring the stuff you would if you were staying in a hotel. I'm sure the other Anchorage companies are fine too. You don't stay in business long otherwise.
2gypsies1
Hopefully, this post will be moved to the Alaska forum.
First, you might consider taking the Alaskan Ferry from Bellington, WA through the Inside Passage for a real treat of areas you can't drive to. It's about a 4-day trip. We left our motorhome for a month in an RV park in their storage area.
Many have rented and the best way is out of Anchorage. We did the ferry and rented from Great Alaskan Holidays are were very pleased. We got off in Skagway and rented for 2 weeks from a small operator - expensive but that was the only available. Then we had friends fly in and we met them in Anchorage, turned in our rental and re-rented for 2 weeks from Great Alaskan Holidays - much cheaper. We then toured with our friends for 2 weeks. We flew back to Seattle.
The rental was fun but very expensive. Plus, we felt rushed for the time period.
Later we drove our motorhome up leaving in May and returning in Sept. It was the best trip ever. We had our own stuff. We were able to take our time and explore Canada and the Yukon, also...something you can't do in a 2-week rental period.
Our 40' motorhome fit everywhere we wanted to go. There are so many wonderful boondocking spots in awesome spots overlooking rivers, lakes and mountains. We also used Provencial parks in Canada and the Yukon and some national forest campgrounds in Alaska along with state recreation areas. We stayed in Denali 10 nights at both Teklanika and Riley Creek campgrounds.
Bottom line, there is so much more to see than Alaska. The drive up and returning were great and the animals were plentiful.
We bought new tires before the trip. We were confident in our prior maintenance of the vehicles. That's the only protection we did and had absolutely no issues on the motorhome or Jeep.
Renting is o.k. but driving the distance is better!
Full-Timed for 16 Years
.... Back in S&B Again
