HARLYGL94's avatar
HARLYGL94
Heading south from North in February
If I were to go south from Massachusetts in the month of February are there any campgrounds that are open so I can get electricity? Possibly in Pennsylvania and Virginia? Thanks so much if anybody has any information for me.
  • Oh yes I forgot all about that when I could run off the batteries that's right and so I guess I wouldn't have a problem I have a class C Winnebago 30 ft it only has 8000 miles on it with brand-new batteries. Thank you so much for the information can you tell I'm getting old and forgetful and lol
  • JaxDad's avatar
    JaxDad
    It's very difficult to give you a good answer, your profile is blank and you don't have a signature that tells us what type of RV you have. I can tell you what works for me though. I have a mid-sized Class C.
    First off I travel with the rearmost roof vent open, between an inch and wide open and the heat set to dash and pointed back. This points the hot air towards the vent which is vacuuming it further back. I can keep the entire coach pretty warm by just this method. That means the whole coach is much warmer when I stop for the night.
    By the time I stop the coach batteries are fully charged and the interior is warm. I set the thermostat to about 60 deg. and get under warm blankets. The furnace doesn't run much overnight.
    Early the next morning I'm up, the engine is running, making heat and recharging the coach batteries.
    I've overnighted in some pretty cold temperatures, not a single problem yet.
    BTW, your furnace runs on 12 volts, so as long as you have decent batteries and limit run-time you should be fine.
  • Well doesn't the furnace need electricity to click on and off so wouldn't you need to generator running? Thank you for your response
  • Why would someone run a generator all night in cold weather instead of their propane furnace?
    However, we have run our RV's generator nearly all night in a Walmart parking lot in the Southern U.S. in August to sleep in the extreme heat and humidity!
  • Do people usually park in like a Walmart in the cold weather and run their generator all night? Or Cracker Barrel etc.
  • Just north of 78 on 81 in pine grove PA. It used to be a KOA but it's not any more. Can't remember the name (age) but it's open all year and and we stop there on the way home in the fall and at times after New year's.
    Twin Grove Park and Campground
