โDec-23-2013 06:08 AM
โApr-29-2014 05:56 PM
LenSatic wrote:NinerBikes wrote:profdant139 wrote:
Bionic, that fuel cutoff is a phenomenal idea -- the only way I can run my Honda carb dry is by burning the whole tank, a time=consuming waste of money. But a dry carb is the key, they say, to avoiding gummy crud. Why can't Honda do that? It is not as if the Honda 2000 is a budget device! Grumble.
Take a quarter, undo the screw, pull the cover off. Take a small screw driver underneath the carburetor float bowl, Twist counter clockwise until fuel comes out the tube near the foot of the generator. once it stops draining, twist the screw clockwise, closing it. Your carb is now drained. Leave the engine setting in the "off" position, choke the carb, and pull the starter handle 3 times firmly, without starting the motor up. You've now sucked all the fuel out of the fuel jets also. Ready for storage.
Thanks for the info! I've just kept Sta-Bil in the fuel cans and run Sea Foam through the Honda.
Can I borrow a quarter? ๐
LS
โApr-29-2014 05:08 PM
โApr-29-2014 03:05 PM
โApr-23-2014 09:45 AM
โApr-22-2014 05:28 AM
โJan-22-2014 08:48 AM
โJan-01-2014 08:08 PM
riven1950 wrote:
Thanks for the link 2oldman. I had found some of that, but not all. I am thinking I am seeing a Champion3100 or a stack of Champion2000 in my future.
BTW: Supergen has refurbished stacks of Ch2000 for sale. Anyone have experience with them? I realize most people, including myself would not normally consider refurbed, plus only a 90warranty. Just wondering if there is any REAL world experience with them.
Thks
โJan-01-2014 04:27 AM
โDec-31-2013 07:25 PM
โDec-31-2013 06:45 PM
profdant139 wrote:
Don't get me started about changing the oil on the Honda!! I made a PVC spout that fits into the oil drain hole, and that makes the job a little easier. But why didn't Honda give us a drain valve?? How hard would that have been on a thousand dollar generator? Does the Yamaha have an oil drain valve?
I am talking myself into getting a Yamaha, if and when I have to replace my Honda.
โDec-31-2013 06:40 PM
profdant139 wrote:
2oldman, yes, one can siphon the gas, but it is a messy process. If only Honda would give us a shutoff valve like the Yamaha, we could easily dry the carb and avoid gummy crud and avoid "surging" due to bad jets and avoid expensive service calls. One would think that Honda would want to enhance the image of its generators as "user friendly," to help justify the price tag.
โDec-31-2013 10:08 AM
riven1950 wrote:3100 in heading in tech
. Would be very interested if someone actually has a Champion3100 and they can relate their history with it as far as noise etc.
โDec-31-2013 06:25 AM
riven1950 wrote:
Bumpy I like your idea with the plywood, although in my case with a 18 foot TT it seems it would be too easy to move the TT off the plywood. Or am I missing something?
mlts22 do you hook up and run the genny while it is in the truck bed?
I agree a thief with bolt cutters could ruin a good security measure, but they do make some pretty tough security cables now. Luckily most crack heads and thieves of opportunity do not have bolt cutters.
โDec-31-2013 04:08 AM
I believe that the person who came up with this had a motorhome which would be a little more difficult to push around. ๐
are those "chocks" that go between the two tires and expand lockable in some way?
bumpy
