how to leave home
ceasare
I'm sure this has been asked before but what do you do to the sticks and bricks when leaving for the winter? This is our first year of snow birding. We leave about 1/3. Going to Quartzite and Yuma and wherever. LOL. Happy Days!!!!
35 REPLIES 35
Michelle_S
Home base in Western New York (Rochester/Buffalo area) We remove all food items, turn off the water, drain and blow all remaining water from the lines including the hot water heater. Add RV Antifreeze to all traps and toilets, lock and bolt the doors, call the electric company and have the power turned off. Place is listed as a seasonal residence with our insurance, so we're pretty much covered. If it were to burn down or get blown away, we're be Full Time RVers instead of Most Time RVers.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
MountainAirMan
And above all, don't announce your plans to vacate home on any social media outlet. ๐Ÿ˜‰
Lyle (the other one)
phillyg
Down here in Fl when my snowbird neighbors go back north or to Europe, they get pool and lawn services started, leave the AC set on 80 degrees, turn off the water, and arrange with a neighbor (or hire someone) to check the house on a regular schedule.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Fizz
Brother in law did everything right, turn off the water etc.
Neighbor comes in to do a check and finds water all over.
The tank on the brand new toilet cracked and dumped its 5 gal of water. Could have been much worse.
almcc
For peace of mind, we have a smart thermostat and subscribe to a service where I can look at/reset the thermostat and what the temp is doing minute by minute, and it will email me and our house checker if the house temp drops 2 degrees below set point.
DougE
If you shut off water to the house and open the interior taps the pipes are unlikely to burst. The water pipes in the exterior walls will get to roughly 1/2 the temperature difference between the interior and exterior. I.e. If its 0* outside and 60* inside the pipe temperature will be ~30*. Draining through the exterior hose bibs will probably get the water in the pipes to the lowest level. (Put an insulating cap on them also.)
If you have a programable thermostat you can raise the interior temperature of the house another 10* between 4:00 and 6:00 am.
It's best to cut off the power source to the water heater, whether gas or electric.
Anything you can do to add insulation to your windows will do wonders for your fuel bill. (For long term non-occupancy I'd cut something like foam board to fit the opening.)
If it gets cold enough for long enough even insulated pipes will freeze!
Currently Between RVs
DutchmenSport
If the house is going to be unoccupied, at a bare minimum, winterize the water system by draining the water heater and blowing out the lines in the house with an air compressor, just like you'd do on your RV. Turning the heat off completely, especially in snow states, is not good for the walls in your house. My mother went to Texas one year over the winter and I policed her house. We agreed to keep the furnace (hot water system) set to 40 degrees where it stayed for about 4 months. This kept any pipes from freezing, yes. But once she returned home, raised the heat back up, and then Summer came around, she had several rooms in the house on the outside walls that started flaking paint. The house was built in the 1940's, so the walls were real plaster, not plaster board. It was the first time ever anything like that ever happened.
However, if you are going full timing ... best advise is ... sell the house and then you have no worries any more about anything and you'll really be free to enjoy your new-found lifestyle.
bobsallyh
Absolutely turn off the water! Then turn off the energy source for the water heater. If electric, kick the breaker, if gas, turn off the pilot light. If you have a driveway, make sure newspapers, or anything dropped off doesn't sit there for a long time. If somebody is going to be checking the inside, have them bring along several buckets of water to flush the pottys' with.
spud1957
Call your insurance company and confirm what your obligations are. Do not just rely on posts from strangers on a forum.
If your policy states you are to have someone check on your house and/or have a 24 hour monitored alarm service, and you do not, they have every right to deny certain claims (water) while you are away.
This is clearly stated in my policy (Co-operators).
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
jplante4
Boy, if I had to do all that alarming and securing, I'd sell the place and move. Also, any internet enabled security system requires you to leave your internet on. That's an expense you really don't need.
Turn off the water and set the heat to 50 or 60 if you have a newer high-efficiency furnace. Water heater off (vacation mode still burns gas).
If you have forced hot water heat, you will need to provide makeup water to the boiler. Most people have a separate line for the boiler that allows you to isolate the rest of the house. Route any P/T valve overflows for a sump with a pump.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Captain_Happy
I've got an even better idea. Sell the dam house and go enjoy life for once.
The above posts pretty much cover what I do. In addition, I put the Comcast Triple Play services on vacation hold. Saves about $400 over the 3 months we are gone. Also, stop garbage service for additional savings.
Forward landline to cell.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
Edd505
Yes turn the water off. Got a call from the water company "we shut the water off at your house. You have an $800 water bill and we know your not home and think there is a problem". Got home to find the float in the master bedroom bath had sunk and allowed the toilet to run until they shut it off. Friends & neighbors were watching outside.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
old_guy
right now qvc has blink security systems on sale for 249.00 and they can be viewed on the internet through your cell phone
Dick_B
Shut off the water. For internet cameras look at Simpli Safe or one by Lambow. You need wifi in the house but they really do work and give you some peace of mind while you are gone. We have five such cameras.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
