Ivylog's avatar
Ivylog
Jan 28, 2016
I'm getting tired of El Nino.
The El Nino pattern is living up to it's reputation as a conveyor belt for storms across the southern US. Usually winter in Florida is the dry season, especially in southern FL. Most cold fronts come out of the north and stall out around Orlando. The few stronger ones usually push south of the keys with a hour of rain as it passes and a day of cold weather.
In ten years of Snowbirding in WPB I've only put my awning in three times because of thunder storm warnings in the cold fronts. I've already broken that record and I'm glad I did put it in. Having grown up here you could count on one hand the number for days where it rained all day in a year. While January has not broken that number YET and instead of less than 3" of rain... we are pushing 10" for the month, enough is enough.
With El Nino the fronts are coming out of the west across the gulf where it's picking up a lot of moisture... hence all the rain. I doubt TX is getting as much rain from the same front as by the time the front gets there, CA has sucked most of the moisture out of the front.
While it's serious when two are killed in Sarasota by a tornado or cars are blown around yesterday in Ft. Lauderdale, BUT I bet those in tornado alley would be happy with a E-1 that's less than 200' wide and stays on the ground for a couple of minutes. Must be a slow news day when the one yesterday makes the national news.
I know those of you in CA dealing with mud slides or you in the DC\NY areas dealing with record snow do not feel sorry for me but dang I can't do this all of the time. :B
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,716 PostsLatest Activity: Feb 10, 2025
