agesilaus
Aug 06, 2020Explorer III
Intergencies passes
Using Rec.gov to make reservations at COE cg I have run into a bug in their software that blocks your use of an Access Pass and I assume all the other passes as well. Here is an example:
1) Check in a COE cg A on say 1-1-20, stay several days and check out on 1-4-20. All good so far
2) Travel over a hundred miles to COE park B and try yo reserve an open site starting on 1-4-20.
3) The software will reject your pass as having been already used on 1/4 even tho checking out is not using the pass?!
I sent an email off to gov.gov but do not expect much help. I guess we will call them.
