profdant139's avatar
profdant139
Aug 31, 2018
Maps of ranger district boundaries? (Yes -- see below!)
You'd think that the ranger district boundaries are pretty trivial -- sort of a "who cares" issue. But here is why it matters -- in most national forests, the Motor Vehicle Use Maps (crucial to boondocking) are keyed to the ranger districts.
So if you have seen a specific area on Google Earth that looks like it would be good for boondocking, it is very tedious to go to the relevant National Forest website, download the several MVUMS, and try to figure out which one is pertinent to the area you are looking at. It can be done, but it can take a long time. The MVUMs, while valuable, are tough to read; often, the main highways (which are useful for orienting yourself) are shown as very faint lines, and are not always labelled.
Does anyone have a solution for this annoying problem? Your suggestions will be appreciated!!
  • huasnaian, looking at that photo, it seems that you escaped the smoke -- excellent!
    We have tried Avenza a couple of times -- it does not always work for us, but we will try it again.
    The only trick that I would add to your description is that instead of creating new tabs for each map or app, I often create new windows -- I then set them up side by side, so that I can more easily cross-compare the info on one map to the info on another.
    So, for example, I will have both the MVUM and Google Earth open, to see where boondocking is allowed and what kind of terrain it is.
    There are keyboard shortcuts for looking at two or more windows, side by side, for both Windows and Macs. (I drive a Mac.)
    The only limitation is the size and number of your monitors. I have one big monitor, which I often subdivide, and one smaller one. So I sometimes have three different maps going at the same time. This is a very high-tech method of acquiring a splitting headache, accompanied by acute eyestrain. ;)
  • Barry- Thank you for a link to this map, this will be very helpful in the future.
    Profdant- I agree it is very cumbersome to cross-reference multiple maps. Here is my method and a few things that might be helpful. I have a truck camper and when I go out I am looking for areas to ride my motorcycle (street legal dual sport) and frequently use MVUMs. I know you are more of a hiker and might be seeking slightly different locations.
    I start in a different direction from you. I first locate an area that I know has a large forest service road system and hopefully some true motorcycle single track. Since forest service websites can be hit and miss depending on district I start with google searching 2 phrases. "MVUM + the general area of interest", and "recreational opportunities guide + area of interest". Once I find an area that has legal motor access to the forest I then go to google maps/earth and start exploring from above. Some districts will post a Map Index which will show the relation of the different maps. If the district doesn't offer the map index, I find where a forest service road meets the regular road on the MVUM and search for the intersection on google maps.
    If you only have a pin dropped on google maps I find that the quickest way to match up the two areas is using publiclands.org in a second tab, locate an easy to find area on both maps, and then use publiclands.org to follow the road of interest to make sure it does not cross over any private property. There is an area near me in the los padres nf that is listed on the MVUM as open but it crosses private property and the owner never opens his gate to allow access. Luckily I did not drive a long distance to discover this blocked path.
    One really handy app is Avenza Maps ( I use it on android, not sure if it is for iphone too). The free version of this app will allow you to have 3 maps loaded into it. If you download the MVUMs to your android phone and then import them into Avenza Maps, the app uses the gps on your phone to put a marker on the MVUM of your location and allows you to drop a pin to mark a location directly on the MVUM. I find this helpful once I am exploring the area to see exactly where I am within the forest service road system. I have also been able to load hiking and mountain biking maps into the app which was a nice surprise.
    I am sure you are aware of most of these tools but that is how I use them together to find my way around the forest.
    Am I missing any cool tools that you use?
    I just got back from the High Sierra Ranger District this last weekend. This district has a very well put together website with lots of maps and relevant info. The Tamarack area just below Huntington lake was not very crowded where Shaver Lake was a madhouse. Also, out Dinkey creek road, to the Courtright reservoir was a very nice drive on paved roads with plenty of forest service roads to explore. Here is a pic from standing on the Courtright dam.
  • ppine, they are usually not available on line, as far as I can tell. Again, I could be wrong, since I was unable to find the map that Barry found!!
  • ppine's avatar
    ppine
    Get a US Forest Service map of a NF. It will show Ranger Districts.
  • Forest Maps app. You load the maps forest by forest on your phone or tablet so, for instance, I only have the forests I frequent. Also shows where you are with an icon. Good for back road driving.
  • like this one maybe
    https://databasin.org/datasets/92fd496ce8af46fc94cca2e8c1fb7c93 click on the map and it will open up
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,761 PostsLatest Activity: Aug 31, 2026
