- autiger74ExplorerThanks for your help. I think I'll try for Mesquite.
- wtmtnhikerExplorer
accsys wrote:
We have stayed there twice, last year and also in 2011. We stayed in site 85 one year and site 81 the other. Both were easy back-ins and more than sufficient for our 40 footer - a 45 footer would have easily fit in both. You site is assigned upon arrival but you will have your pick of what is available for your stay.
That's right, when you get to the area of your assigned site and you see a site that you would rather have just go to the camp host and request a change of site. If they haven't already given it out you likely will be able to switch. - accsysExplorerWe have stayed there twice, last year and also in 2011. We stayed in site 85 one year and site 81 the other. Both were easy back-ins and more than sufficient for our 40 footer - a 45 footer would have easily fit in both. You site is assigned upon arrival but you will have your pick of what is available for your stay.
- wtmtnhikerExplorerWe hosted there in 2011. You really can't go wrong with any of the campsites for scenery. It is correct that Sagebrush & Mesquite have 50 amp outlets. Hackberry has the most wildlife roaming around. We'll be there in a couple of days, we'll need 50 amps but for our space heaters!!
- HeisenbergExplorerIn July? It is a tough place to be. Anywhere away from the 50 amp service.
- kennethwoosterExplorerGreat place to camp. Should be pretty this year with all the moisture. July can be hot we went down in the spring, and it was really nice. Enjoy.
- 4huskersExplorerMy understanding is that the TV and cell reception is better in Mesquite. We stayed at Hackberry three years ago in April and it got hot. I hope you have two air conditioners for camping in July. One of the prettiest spots in Texas. Great mountain biking trails.
- BB_TXNomadLooking for full hookups? 50 amp?
There are three areas with full hookups, two of those have 50 amp and 30 amp, the other only 30 amp. In July if you have two ACs you will need 50 amps. And it would be a good idea even if you only have one AC as it will be HOT.
The first 50/30 amp area you come to is Sagebrush camp area. Shortly after you drop into the canyon and just across from the amphitheater where the musical Texas is presented.
The second 50/30 amp area,Mesquite camp area, is at the far end of the park road.
The 30 amp Hackberry camp area is between the two, a little closer to Sagebrush. This one has the most trees, although not every site has them, but again only 30 amps.
Mesquite has probably the best and prettiest views. But you have to cross 5 low water crossings. Not normally a problem as they are smooth transition concrete crossings that are normally dry. But if there happens to be rain storms move thru, there could be a problem getting into the area, or in getting out of the area, until the water goes down. That is not normally long, but could be an issue.
No low water crossings for Sagebrush camp area. And the views there are also good.
You really can't go wrong with any of them. I thought the back in sites were well spaced. Not many pull thrus as I remember.
Here is a park map.
You can also use google maps satellite view and zoom in pretty close to get a view of the camping areas.
And you can also use google maps street view to see the camp areas up close and get a really good idea of what to expect. - agesilausExplorer IIII could be wrong but it seemed like they assigned us a campsite when we arrived. The pull thru sites are the best the others can be on the tight side.
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,719 PostsLatest Activity: Mar 05, 2025
