Hybridhunter
Sep 02, 2013Explorer
To the OP. Since you are going to be full timing. I agree with those that say do a nice solar setup. Your tow vehicle alternator can be used to charge your batteries if the sun hides for a few days. This method is not as inefficient as some think, provided you have a fairly efficient vehicle, a decent alternator, and fairly depleted batteries.
It certainly is cheaper than a good genset if you are only using it as a backup. You can always buy a genset after the fact if it doesn't work out. I did the opposite, bought a few different generators, got rid of all but 1. I use the truck as plan A, genset as plan B.
Edit - I run a Grp 24&27 battery, with a 1500 watt inverter. The only time I need to idle the truck to use things are when I'm running the 6000brtu AC for more than 30 mins.
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,741 PostsLatest Activity: Jan 13, 2026
