โJul-18-2013 11:27 PM
โOct-16-2013 03:49 PM
RoyB wrote:
It has been my experience to beef-up the trailer first to run all the things you want to run from the batteries. Then add the 2KW generator to that to be able to connect to the shore power cable to allow your on-board smart mode converter/charger to recharge your batteries in as little as three hours time which is the only way to be able to recharge a deep cycle battery setup.
Using the generator is the only "sure" way to re-charge your batteries as it will work in all weather situations.
Once you get successful running all the things you want to have with you then start adding some solar panels just for the purpose of re-charging your large battery bank during the daytime when the sun is out...
This is where I am now in my long term beef-up for camping off the power grid. As you start increasing the solar panels then you can start cutting back on the use of the generator. Eventually you can go several days without running the generator at all and still be able to run all the things you want to run.
But what I have found out you will need to always have the generator around for that last PLAN B effort for keeping the batteries re-charged. You may go weeks without much enough sun light to run the solar panels...
Got to have the PLAN Bs to be successful camping off the power grid...
Just some of my thoughts on how we have progressed along the camping off the power grid experiences...
Also if you are lucky enough to be able to have your RV Trailer parked at your house when not on the road then all of your Battery beef-up planning is like having a large UPS system for your house when bad weather storms knocks out your power for weeks on end. I have used my trailer setup to support the house on four occasions now, One event was for over a week without power here in the county when one of hurricane Irene came through a couple of years ago... this payed us back big time and also helped out in the community here helping folks keep their fridges powered up a couple hours a day. My neighbor RV guy and I put the 2KW Honda generator in a kids wagon and visited all the local elderly folks houses and kept their fridges going. All it cost was a cup of coffee and some conversations hehe...
Roy Ken
โOct-11-2013 12:56 PM
profdant139 wrote:
Niner, two ideas -- first, have you considered group 31 batteries, with 110 amp hours each? And 22 watts for the bulbs seems high -- warm white LEDs draw about 5 watts and give plenty of light.
โOct-10-2013 01:40 PM
pnichols wrote:
Mark,
Are your solar panels attached to the trailer roof with adhesives ... or with bolts through the roof?
โOct-09-2013 09:36 PM
โOct-09-2013 09:10 PM
โSep-09-2013 12:03 PM
โSep-09-2013 03:49 AM
โSep-06-2013 05:03 PM
โSep-06-2013 03:53 PM
โSep-06-2013 03:34 PM
RoyB wrote:
A 3000WATT load will drain around 250AMPS @ 12.2VDC from your battery bank. Thats a bunch... I imagine the 3000WATT Inverters will require a 400AMP protection fuse be installed between the Inverter and the battery.. You will need a bunch of batteries to sustain this.
We camp alot off the power grid and our biggest load of course is between 8PM and 11PM watching HDTV etc... We use a 600WATT PSW Inverter. We do just about everything we do at regular electric sites except no air conditioner or no high wattage microwave when camping off the power grid.
We will draw around 20AMPS for these three hours from our 255AH battery setup. This along with the usual 1AMP or so draw for parasitic drains all day long will run down our battery bank to around 12.0VDC (approx 50% state of charger) by 8AM the next morning. This is when we will re-charge it back up to its 90% charge state by connecting the 30AMP shore power cable directly to our 2KW Honda Generator. Using smart-mode charging technology this will take around three hours to do which fits into the times allowed by most boondocking camp grounds to run a generator.
We can do these 50% to 90% charge cycles with our battery bank for 12-14 days before we must re-charge the batteries back up to their 100% charge state otherwise it will start doing damage to our batteries. Using the 2KW Honda generator to re-charge to the 100% charge state will take around 12-13 hours which most boondocking camp grounds will not allow you to run the generator this long of time here on the East side of the US so this is usually when we head for the house.
Of course all of this does not include use of Air Conditioning or high wattage microwave.
Usually lots of shade so don't miss the air conditioner anyway...
Roy Ken
โSep-03-2013 06:56 AM
โSep-02-2013 08:52 AM
โJul-27-2013 11:40 PM
โJul-27-2013 09:55 PM
BoonHauler wrote:
Magnum Inverter/Chargers are the best!.....bang for the buck that is :B
Magnum Energy
