May-07-2015 07:53 AM
May-15-2015 06:19 PM
BoonHauler wrote:Darryl&Rita wrote:
Please do us all a favour, and use the proper cable connectors. There's a reason the NEC has different specs for different voltages.
not to mention the power drop ......
May-15-2015 08:21 AM
May-14-2015 07:56 PM
May-13-2015 07:02 AM
May-12-2015 06:59 PM
frizzen wrote:BigSkillet wrote:
I'm looking at this as well. Since I have no knowledge, do you run it directly to the battery compartment when using it?
You can get them with or without a built in charge controller. If you have the controller all you have to do is put the clips on the battery. The leads will be about 15 feet long.
I have 2 of them without controllers that feed into a 30 watt pwm. Waiting to take the rig out and give them a try. I riggged up a 50 foot cable out of some wire that I have had for a while. THis lets me park in the shade and put the solar panels in the sun. In direct sunlight I was getting 21.5 volts and 11.3 amps at the end of the cable.
May-12-2015 07:24 AM
wbwood wrote:JiminDenver wrote:
Here is the manual to that inverter.
Suresine 300
Someday I'll get around to upgrading our 150w inverter. It's a good fit but the fan will drive you nuts after a while.
Yeah saw that, but to me it's foreign....lol
Might be able to get my father to help me out with it.
May-11-2015 11:24 AM
Suresine 300
May-11-2015 06:26 AM
May-11-2015 05:40 AM
Mello Mike wrote:
As for your inverter, I'm not sure what you want to run and how much wattage you'll need, but I've found the Morningstar Suresine 300 more than ample for our electronics.
May-09-2015 12:25 PM
May-09-2015 04:39 AM
May-08-2015 07:57 PM
wbwood wrote:4aSong wrote:
Brian,
We have the Renogy 100W suitcase also and on our 1st. two week trip in Arizona we found it to work fantastic on keeping our two 12v batteries charged. Did not need to use the Honda 2000i generator during the two week adventure. Knowing this I would have purchased it sooner.
I'm sure you will be very satisfied with the unit.
Thanks...we will be sure we will like it.
WE did get the one with the controller, but noticed they sell them without the controller. Can you hook up one without a controller to the controller on the one with it?
May-08-2015 02:50 PM
4aSong wrote:
Brian,
May-07-2015 07:32 PM
