rrevExplorerNov 20, 201512v led wiringI'm trying to figure out how to wire a led strip inside my pass through compartment that has a push button to turn on the light when you open either door.Do I need to run wires from one side to the ot...Show More
navegatorExplorerNov 20, 2015Wire it the same way as a stair in a house, with double pole double trow switches and yes you will need to run wires across the bay.navegator
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
Related Content12v wire thicknessFleetwood Angler wiringHow to adjust LED headlights?2005 SixPac D850 Wiring120v Wires Near 12v Wires - -Problem?
