I'm trying to figure out how to wire a led strip inside my pass through compartment that has a push button to turn on the light when you open either door.Do I need to run wires from one side to the ot...
You could just use a 9V battery and it's connector as the switch to power a 4' section on each side. Would be a good use of the smoke detector batteries we throw away each year. Use Velcro to mount the battery and just pivot the connector over the other terminal to connect it... no need to snap the second one in.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
