12v led wiring
rrev
I'm trying to figure out how to wire a led strip inside my pass through compartment that has a push button to turn on the light when you open either door.Do I need to run wires from one side to the other between the switches like a 3 way in your house? Do I need a special switch? Anyone ever do this?
2008 Chevrolet Silverado 2500HD CCSB
2016 Starcraft Autumn Ridge 329BHU
2007 Starcraft Homestead 282DBS (Retired)
17 REPLIES 17
Ivylog
Chris is saying to power it from both ends with simple on/off switchs. Put 12V to the red leads.
Upgraded with a 08 HR Navigator 45โ€™...
Chris_Bryant
You don't really need to be complex- having two hots will be fine if you think about it. You don't need to turn it off from either side- just on.
-- Chris Bryant
navegator
Wire it the same way as a stair in a house, with double pole double trow switches and yes you will need to run wires across the bay.
navegator
