RLS7201
Oct 15, 2019Explorer II
Canuck_in_NJ wrote:
not a tone of room on this small tongue, but angle iron might be the trick. Didn't want to put a ton more weight on the tongue, but may be easier than the truck box.
Bolt that angle iron to the tongue and mount those 6 volt batteries for and aft, for less width. After you get the iron cut and mounted you may want to stop by the local weld shop for the end pieces.
Richard
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Dec 11, 2017
