A Few Mods before Winter
12thgenusa
We used the trailer pretty well this year, 89 days including a 75 day trip to Alaska. This along with some recent posts by others gave me ideas and plenty of time to plan some new mods.
RVcircus posted a video of installing a Smart Tile backsplash in the kitchen.
So I ordered some Smart Tiles from HD and did the same. Itโ€™s fairly straightforward, however they donโ€™t tell you how to handle the fact that wall corners and countertops rarely meet at 90 degree angles. I made a couple of small goofs and also had to patch together some trimmings to fill out the area, but overall I am pleased with the result.
The rear kitchen layout has more counter space than other floorplans but there is only one light above the sink and if you are working on the end of the counter you are blocking the light from the room overhead lights. I added a second light beneath the cabinets.
The bathroom has no heat vent and the door is always closed so it can get rather chilly during the cooler times of the year. I saw where
bartlettj had added a heat vent so I thought I would do the same.http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28853911.cfm
I bought the furnace flange on ebay for $6 including shipping, the round register from CW for $7.59 and the 4โ€ duct from HD for $10.65.
Itโ€™s a bit disconcerting to drill 4โ€ holes in the bathroom floor and several wall cabinets but the installation went smoothly and we should have a toasty bathroom next spring. There were three blanking plates on the furnace and this summer they all fell off when traveling some of the rough roads in Alaska. I took the opportunity to add a sheet metal screw to each so that wonโ€™t happen again. (If youโ€™re getting low airflow out your heat vents you might check your furnace for the same problem).
The next is a small but annoying thing. When setting up I seem to generally forget to unlock the tabs on the outside flap for the stovetop vent fan. Along about supper time, DW asks โ€œdid you open the flapโ€? Sometimes the tabs can be reached from the ground, but if the site is not level, you may have to climb partway up the ladder to reach the tabs. You also have to remember to close it when getting ready to travel. I decided to add a mechanism for opening and closing the flap from inside the kitchen.
I bolted an angle bracket to the inside of the flap to which I attached a small clevis. Several pieces of 3/16โ€ steel rod were bent to fit through the duct and out through a slot cut in the side of the fan box and threaded to accept the clevis and the coupler. Several screws were added as latching pins. To open, the handle is lifted and pushed aft and latched behind the aft pin. To close the handle is lifted, pulled forward and rotated in front of the forward pin. I really wanted to use a mini linear actuator with a 1โ€ stroke, wired through the fan switch, but didnโ€™t want to spent the $$.:)
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
11 REPLIES 11
93Cobra2771
Love the flap actuator!
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
DrewE
I agree, very nice work all around!
Another approach for a flap actuator (in case someone else is thinking of doing something similar) might be a push-pull bowden cable, such as is frequently used for lawn mower throttle controls. I might be interested in this if my RV's range hood vented to the outside, but alas it only circulates air inside the RV (and makes rather a racket in the process).
mikakuja
Nice work!
12thgenusa
That was the best pic I could get. The opening is only about an inch so you can't see very far back. What you see is the fork end of the clevis bolted to the angle. The clevis is about two inches long and the rod is threaded into it. About two inches farther back the rod bends 90 degrees and comes out the slot shown in the next picture. There is no swivel.
popeyemth
Could you post a little better picture of the attachment at the flap?
Can't quite make out the clevis and swivel.
Thanks,Mike
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
RollandB
very nice work. That heat duct could come in hand on cold days if you heat it first before sitting down.....;-)
2013 Yukon
2021 Coachmen Spirit 1943RB
Roger10378
Good job on all three things. I did the smart tiles a couple of years ago and they still look like the day I installed them. I have had the furnace blanking plates fall out so I used duct tape on them. I like your vent actuator but it would be difficult on mine as the fan is part of the M/W. I'll have to give that one some more thought.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Rbertalotto
+2 on the exhaust vent mod! VERY Clever!
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
downtheroad
Love the exhaust vent opener....
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
westend
I know the off-square aspect of your kitchen counter area had you pulling hair but it looks great! The flapper mod is a thing of engineering beauty. It's probably best you didn't use an actuator. They are prone to break-downs and it is just one more thing that can go wrong. Nice work!
'03 F-250 4x4 CC
ScottG
Nice work!
Been thinking of doing the tile thing in my own TT. I have the same basic layout except my range is to the right of the sink.
How does the grout part work or is it part of the tile?
Looks fantastic!
