AC/heater thermostat replacement
old_guy
My son in law and I have the same domectic thermostat for our AC/ heater and it is analog. we are thinking of going electronic or digital. what do you all recommend for the replacement?
7 REPLIES 7
Isaac-1
Take a look at these couple of youtube videos
https://www.youtube.com/watch?v=lOPtLUTmHIc
https://www.youtube.com/watch?v=RFmyzGhHIgw
https://www.youtube.com/watch?v=6CPtV_iX9GQ
note color codes vary by rv manufacturer
Atlee
Is your current thermostat a Dometic branded thermostat? If so, I would replace it with a digital Dometic thermostat. There should be a straight wire for wire switch.
It was for my Coleman thermostat.
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
downtheroad
I went with one of these...comes in white or black. Straight swap from the analog.
Call rvupgrades with your furnace and A/C info and they can get you the correct model for a wire to wire swap...
Works great. About a 1 degree swing for cycling. Also controls fan speed (hi or low)
Digital Stat....LINK
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Farmboy666
Digital Honeywell
donn0128
As long as what you want to replace is not one of those cruddy priporatory things, then any self power thermostat should work well. I used a battery powered Hunter Douglas with great results. 25 dollars from WalMart. Much better that the wild swing one that came,from the mfg.
time2roll
I went with the Dometic single zone Comfort Touch. Has worked very well for us.
2oldman
Lux w/remote.
