tommymsw's avatar
tommymsw
Adding more solar panels question?
I just got a 2000 Winnebago Adventurer 35B. It has a small solar panel on it already that seems to charge the batteries.
If I wanted to convert to solar to avoid using the generator, would I be able to simply attach more panels to the existing one and use the same system? Or do I need to just start from scratch and install a second, separate solar system?
About DIY Maintenance
