SJ-Chris
Aug 31, 2022Explorer II
Adding simple fan, Looking for RV vent fan bracket...
I recently replaced the motor and fan in my bathroom vent on my Class C RV. Very easy/quick job.
![](https://i.imgur.com/7JOunqol.jpg)
It got me to thinking...it might be nice to have a small fan on some of my other ceiling vents in the RV (currently, they do not have fans). There is power nearby (ceiling light). The vent already has the support bar for the open/close lever, and I can see it has holes where a fan bracket could go.
Can any of you tell me where I could find this bracket (circled in yellow) for a fan?
![](https://i.imgur.com/yieZL5al.jpg)
It could be as easy as adding that bracket and then installing the fan & blade and then tapping power from the ceiling light through a small switch (...I can even see the vent screen/cover trim has a punch-out for where a switch could be added).
Yes, I am aware there are MaxAir, and Hengs, and several other units that can be installed. But I'm thinking a bathroom type 6" fan might be simple and inexpensive (~$25) to install. Could use a forward/reverse type switch that would allow for blowing in or blowing out. Good idea? Bad idea?
-Chris
-Chris
