- Bruce_BrownModerator^^^ I can say "probably not". Our MH has toppers, our TT does not. The first year we owned the TT I didn't get the slide in before it snowed. It was a mess. I ended up just waiting for a melt before getting the slide in, something you can't do if you need to get home.
With a topper, depending on how it lands, it should almost fall off as it rolls in, even if there is some crusting of the snow is involved. - drsteveExplorer
2. How about snow? We camp during many of the winter months also and more than once have had several inches of snow accumulate on the topper. Sometimes it will sweep right off but I have had the situation where it was badly stuck and a nightmare to remove the snow/ice.
Are ice and snow easier to remove from the top of a slide than from a topper? Curious because I just bought my first trailer with a slide. - MeandMyLabsExplorerSlide toppers are relatively easy to install provided you order the correct size for your slide(s).
The real question though is "Do the benefits outweigh the disadvantages?"
Benefits:
1. Keep inside a little cooler.
2. Less water on top of slide to drip inside when breaking camp in the rain.
Disadvantages:
1. Wind flap. Any of the toppers I have been around will flap when the wind blows and really gets old listening to the noise in the middle of the night. Yes, I know of a variety of fixes for this including inflatable pool toys or foam noodles.
A couple of years ago when we got several inches of snow and ice during deer season...followed by single digit temperatures, I made a note to myself that this is one option I would not be installing on my next camper. Last January, when we purchased our new TT, I respectfully declined when the dealer tried to convince me to have them installed. We instead opted for a 50amp service and dual ac's. JMHO - mikestockExplorerIt may not look straightforward at first, but after a little thought, the little lever that turns in as the roll is made up is very important. It locks the rolled up fabric on the roller and keeps the roll from loosening up as you travel down the road at 60 mph and ripping the fabric apart.
rhagfo wrote:
GREENReactor wrote:
What's the benefit from adding these?
No need to clean off the top of the slides when pulling them in.
Helps keep cooler in the sun, as the awing shields the slide from the sun.
Also helps keep rain out.
As the the OPs question, as many have said, it's a pretty easy job.
Where? Check your local RV store. PPL also does a good job with them. - rhagfoExplorer IIIHere are a couple links to help.
This information is from the Makarios RV Parts. I found the best measuring and ordering information on this site. I also found them to have the best pricing.
How to measure
E Book on measuring and information - rhagfoExplorer III
Helps keep cooler in the sun, as the awing shields the slide from the sun. - GREENReactorExplorerWhat's the benefit from adding these?
zackyboy3rs wrote:
Where would I order these? How difficult is it as a DIY project?
Just an FYI, these are shipped freight, our slides outside of flanges were 6'-0" and 12'-10", the brackets come in briefcase sized boxes. The awnings in about 6" diameter cardboard tubes, the tubes are about 1'-6" to 2' longer than the awnings themselves. To get the large awing safely to our storage yard, I needed to strap it to the side of the TV. - ICamelExplorerYouTube has some excellent "how to install" videos for RV Awnings.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
