Jan-16-2020 04:50 AM
Dec-11-2020 06:30 PM
philh wrote:
Click For Full-Size Image.
Dec-10-2020 05:33 PM
Dec-10-2020 07:38 AM
Dec-10-2020 06:47 AM
Dec-10-2020 05:54 AM
Dec-09-2020 11:09 PM
Dec-04-2020 02:17 AM
Dec-03-2020 09:53 PM
Bobbo wrote:SJ-Chris wrote:
Very easy solution:
I installed these:
https://www.amazon.com/gp/product/B07ZQJPJMB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
If you put them within ~6-10 inches from your under-cabinet dome lights (if you have those), you can tap off the dome light wiring.
With the correct sized drill bit, it is a 10 minute job! I have a Majestic 28a and I added them to above the couch, above the dinette, and above the bed in the rear.
Good luck!
-Chris
When it says "2.4 amps (one port)" does that mean that if you are using both ports at the same time you only get 1.2 amps per port? There are other brands that will do 2.4 amps on both ports at the same time. For example: https://www.amazon.com/Voltmeter-SunnyTrip-Waterproof-Replacement-Motorcycle/dp/B08FBY351F/ref=sr_1_...
Dec-03-2020 08:04 PM
Dec-03-2020 08:02 PM
coolmom42 wrote:
How does one go about locating, accessing, and identifying the wiring to something like the stereo?
Dec-03-2020 06:10 PM
SJ-Chris wrote:
Very easy solution:
I installed these:
Good luck!
-Chris
Dec-03-2020 05:08 PM
Sep-23-2020 01:53 PM
Sep-23-2020 11:25 AM
