Flyin_Finn
Nov 22, 2022Explorer
Adhesive for insulation foam board
I am redoing a couple sections of the roof on my Fifth wheel.
I removed the membrane of the whole roof. Then I removed the 1/4"plywood and the 2.5" insulation foam from the sections I am replacing, leaving the ceiling panel intact (the way the roof is constructed on this Rockwood Signature Ultralight is that the ceiling panel, insulation and plywood are sandwich-glued together).
I plan on gluing a 1.5" thick insulation panel to the ceiling panel, with through cutouts for the duct channels and the speakers, and then gluing a 1" whole insulation panel on top of the 2.5" panel (matching original thickness dimensions).
Then I would glue the plywood on top of the insulation panels.
My issue is that I can't quite figure out what glue to use.
I plan on using either the R-tech or the Owens Corning panels.
The R-tech panel instructions says to use non-solvent urethane adhesive, which comes in caulking gun tubes. My understanding is that the panels have foil on one side, but not the other side, and I am wondering if each side requires different type of adhesive? Also, instructions tell to apply the adhesive in beads, some distance apart.
But I would prefer to bond the surfaces at 100% coverage. Does any of you know if there is a suitable adhesive, for example in 1 gallon buckets, that I can use to roll (or spray) on for full coverage? Or any other suggestions for gluing the panels together?
I haven't been to the HD store yet (Home Depot, Lowes). I guess I can ask there, if there are knowledgeable staff on site. Thanks for any help.
