kfp673's avatar
kfp673
Jul 17, 2020
Anyone use Quick connect for water hose?
As the title says, I am interested in the idea of leaving a quick connect on the water hose for our travel trailer. We have a small plastic door that has a plastic connector which is again threaded to another connector in the camper. Sorry for the vague terms. I believe what is mounted from factory is 1/2" male to 3/4" female, and that 3/4" female is what the hose connects to. 1- I would like to replace that factory adaptor with a metal one (although the rest of the system is plastic anyway so not sure it matters) and 2- I'd like to leave a threaded quick connect on the camper and on the hose. Because this connection is recessed, it's often difficult to get the hose tight enough to avoid leaking and even spraying out. A quick connect would lave that portion connected and make it easy. Anyway, I see these all over Amazon. Is anyone using them for RV's? and if so any suggestions? Thanks!
About DIY Maintenance
