myredracer
Feb 24, 2018Explorer II
waterboy502000 wrote:Double ditto!!!ScottG wrote:Ditto!!!
This is probably the worst idea I have ever read about on this forum (and that's saying something).
Old-Biscuit wrote:Sorry, but that is plain wrong. REALLY wrong.
Waste tank would need to be FULL and PRESSURIZED to florce flow from waste tank back thru Spray Nozzle, UP 2' then down into hose which would need to be connecged to a water supply system that has NO pressure in order to 'contaminate' the water supply system
First, codes and regulations cover the requirement of backflow prevention devices to prevent backshiphonage of contaminated water into potable water systems. There are several types of devices that can do that and vacuum breakers are the most reliable and safest which is why they are specified. You can find vacumm breakers on places like residential sprinkler systems for example. CGs can have them on every single faucet at a site. Ordinary check valves are not an acceptable substitute.
It is possible for there to be conditions under which there is negative pressure created in a potable water system that can draw contaminated water back into the system. The water pressure within the distribution system can fall below that of the plumbing system it is supplying when high flows are pumped out of a system like when say a fire hydrant is used. Or there could be a water main break or a water main being flushed. Or a momentary pulse in the system pressure. Or a CG shutting off it's main supply could easily cause it. There are other conditions too...
It is NOT the RVIA that decides whether or not a backflow prevention device is required in an RV. It is probably covered by NFPA 1192 which is the standard that covers RV plumbing systems. I couldn't find a free copy of it online the other day when trying to find something else so can't provide a link. Backflow prevention in CGs will be covered by a plumbing code or standard or Health Agency.
Here is Minnesota's Dept. of Health requirements for "Cross Connection Control" for example that is specifically for recreational camping areas. You can find similar requirements across the US and Canada.
If someone thinks a vacuum breaker isn't needed in your RV, you should get your RV-ing licence taken away for good and be banned from owning an RV for life. :M
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
