โFeb-22-2018 01:33 AM
โMar-09-2018 07:04 AM
Atlee wrote:
I'm not being ignorant.
1) I'm going to get a portable back flow preventer to put on my non potable water hose when the spigot I'm using doesn't already have one. If the spigot I'm using already has a back flow preventer, then bad water can't back up anyway.
2) I don't hook up my black water tank flush until it's time to use it.
3) I dump my black tank before I used the black tank flush. I don't hook it up while the black tank is full. Nor do I use the black tank flush to fill the black tank.
5) As for water, I'm beginning to not even hook up the city water to my trailer. I will use the fresh water in the tank. When it nearly empties, I just put some more fresh water in the fresh water tank.myredracer wrote:
We were in a large CG with a few hundred feet elevation difference from upper to lower sites. Someone at the bottom left their site and forgot to remove their city water hose. It ripped the faucet off and the CG had to shut their main supply valve off. So that set up the scenario for water being drained by gravity from all sites above the damaged faucet into the water distribution PLUS water from lower sites being siphoned back into the system. And if someone were flushing their tank and had no backflow prevention, could have contaminated the entire CG. We were leaving the CG that morning and didn't have to worry.
There are many, many real life scenarios where backflow and contamination can occur. It's not a theoretical other universe possibility. Go talk to your local public health authority and see what they say instead of being ignorant and possibly making others sick (or worse).
โMar-07-2018 07:58 AM
โFeb-28-2018 05:49 AM
Atlee wrote:
At this point, I have purchased a back flow preventer to put on the outside of the black tank flush. It should do all that's needed to fix the problem.
โFeb-27-2018 11:06 PM
mikestock wrote:
Had a similar problem in a previously owned Montana fifth wheel. Like you, I found the price for this plastic junk to be outrageous. The thing was manufactured to fail. I bought a generic check valve and other parts to create my own, better version for a fraction of the cost. Functionally the same.
โFeb-27-2018 05:36 PM
โFeb-26-2018 05:07 AM
Atlee wrote:
Can you and any other poster explain to me how water laced with fecal matter can flow back up the over 2.5 feet of water line, out the back of the trailer which is nearly 4 feet off the ground, back through the water hose and into the campground water system?
I understand that a vacuum on the campground water system could suck fecal laced water out of the black water tank. What I do not know is how this could happen unless the black tank sprayer is completely submerged in the fecal laced water. Is this not so?
If it is so, then why would anyone, using any common sense, hook up the water hose to the black tank flush system and open the spigot while the black tank is full? That sounds like someone who wants to over flow their toilet in the bathroom.agesilaus wrote:
When you all come down with gastroenteritis (or worse) you'll spend more than $50 not counting your lost time. That backflow preventer is not there for cosmetic reasons.
โFeb-26-2018 04:54 AM
Atlee wrote:
Didn't mean to start a firestorm, but apparently I have.
A few answers or explanations.
1) I plan on getting a black flow preventer for my hose I used when dumping the black tank.
2) It sounds like some, if not most on here, believe I keep a hose hooked between the spigot at the camp site and the black tank flush system all the time. Never the case. I hook it up when I need to flush the tank.
3) It also sounds like some if not most here think I have a full black tank when hooked up. Not so. I dump the black tank, then hook up the hose to the flush system, and turn it on. I let it spray and dump at the same time, so there is no way "stuff" from the black tank can enter into the hose.
4) There is a vertical run of at least 3 feet before the black flush piping exits the rear of the trailer. The black flush connection on the rear of the trailer is nearly 4 feet above the ground.
โFeb-25-2018 03:43 PM
โFeb-25-2018 12:41 PM
โFeb-25-2018 12:20 PM
โFeb-25-2018 10:00 AM
โFeb-25-2018 06:43 AM
Atlee wrote:
I'm still waiting to hear how, in the real world, and not some theoretical world in a different universe or the comedy world of the movie "RV", fecal laced water can be vacuumed back through the black tank line into the local water system, if the spray head inside the black tank is not submerged in said fecal laced water. Especially when said black water tank is 39 gallons large.
Is most everyone saying the vacuum created inside the black tank is so great it can pull water from the bottom of the tank through the air inside the tank and into the water hose, and hence to the local water system?
โFeb-25-2018 06:23 AM
โFeb-25-2018 05:11 AM
Atlee wrote:
I don't want any thing, device etc anywhere inside my trailer,
whether by the silver ware tray, or inside a storage compartment that "designed" to possibly, or probably, expel water.
I'm trying like heck to keep any water outside my trailer other than inside the water lines and inside sinks, etc.Lynnmor wrote:
My vacuum breaker was installed next to my silverware drawer and above the electrical inlet. On the manufacturers website, it clearly states that the breaker may expel water and should be installed in a location where that water will not cause harm. Here is a spoon to stir your coffee.
โFeb-25-2018 05:10 AM
