All_I_could_aff
Jul 27, 2015Explorer
Jh lady I assume u are referring to the four slots spaced along the bottom? It does not seem to have them on the top, but there seems to be room to add them. Thank you.
Tyler, as far as I can tell the windows are same on the corners. Picture seems a little distorted, but I will double check that before I get too involved! Thank you.
It just seems so silly to have both openings directly over hot items, and 1 blocked by the door when door is open for ventilation.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
