valhalla360
Apr 20, 2022Navigator
BurbMan wrote:
61 dB vs 57dB for an eU2200, seems competitive. Although Honda drops their spec to 48dB at 1/4 load, assume the Champ is similar
I couldn't find detailed info on the Champion but we helped friends pick out a 3400w champion a couple years back and it's pretty good on noise level.
Particularly for inverter generators, you have to consider the loading. At idle our old Yamaha 2400 is super quiet but load it up to max and it's much louder (though still pretty good).
Problem comparing a 2200w vs a 4500w generator is a load that won't push the bigger 4500w generator off idle may be 50% load on the smaller generator and throttled up it will make a lot more noise than the low out put measurement. So you almost have to create a table of loads vs dB if you want to do a fair comparison between generators of significantly different power outputs (really even with similar rated generators).
For us, we don't typically break out the generator unless there is a significant load, so 1/4load on a 2200w unit is pretty meaningless for us.
Update: Found a youtube video where they tested it at 25ft with the exhaust pointing away...seems pretty reasonable:
- Idle: 54dB
- Eco mode off: 58dB
- 1500w hair dryer 60dB
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
