nbking's avatar
nbking
Curtain Hardware
We want to get a cleaner look in our motor home. We plan on removing the valance and replacing the blinds with regular curtains.
I could some recommendations as to the type of hardware we should use to hang the curtains.
  • Thinking whatever hardware holds the valance should be okay for whatever you want to put up. But in my experience if you don't find a stud, it's difficult to secure anything of any weight in the wallboard, even with a screw anchor.
    x2 on the tension rods.
  • I have added some curtains in our bedroom as the day/night shades did not block enough light when we were assigned a site near a street light, or when the sun came up shining in. Therefore, I kept the day night shades and used tension rods pushed up under the valance. I can slide the curtain to one side, push up the shade and open the window if I want fresh air. Not sure about installing hardware outside the window frames on the wall. If you can find a stud, but ours is aluminum, not wood.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
