DIY folding table/bed under 30$
evy
Hey guys.
this is my version of a table/bed for my DIY campervan.
you'll need :
1-2"x4"x96" (be picky, least knots)
1-2"x6"x24"
6-spring hinges
1-latch/lock
4-adjustable table legs levelers
cost me around 30$ (excluding top)
the top and sides will have the same laminate as my counter tops and refrigerator face panel. I will add another plywood on top and cut the corners 1"diam. The top width is 22" I have 24.5" between my two bench and 47" inches in length because the laminate sheet is 48" you need at least 0.5" on each sides to cut it with a router.
If you noticed I used a piece of 2"x6" on one side, simply because I did this project using pieces I had laying around (scrap).
Also when I use framing wood to make furniture I like to take off 1/8"-1/4" on each side of the 2"x4" using the table saw, I just break the corners using sand paper by hand real quick, IMO it looks better.
If you want to see it in action :
https://youtu.be/KodMjc-DyQ8
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
_______________________________________________
DIY conversion build, extended 2010 Ford 5.4L E250 + high top, from Montreal Canada, new to all this so please be patient and clear with me (never built or camped in a van yet)
8 REPLIES 8
profdant139
Excellent! Thanks for posting this.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
evy
profdant139 wrote:
Great! If you get the chance, could you post a photo of the finished project deployed in your van? Thanks.
Sorry for the delayed response.
jenn22
As soon as I opened the box I knew this was good quality. All screws go in perfectly, the paint finish is perfect. I have the DIY SmartDesk Kit with business edition version and the mechanism works very softly and looks very strong. Couldn't be better! I love my DIY standing desk. #diystandingdeskwithAutonomous
MNGeeks61
hm, new user, necro's a thread from 2015 with her first post ever.
Hm, "this is good as price" then a reference to a product, could it be a bot not knowing you can't post a link as a new user?
MrWizard
Moderator
Moderator
this topic is from july 2015
i have my doubts about getting an update photo of the finished project
I can explain it to you.
1997 F53 Bounder 36s
profdant139
About our trailer
Opie431
I am impressed.
eric1514
I like it. Well done.
Eric
2006 Dynamax Isata IE 250
420 Ah batteries
400w Solar
