Dometic fridge exterior door latches.
Flatfive
I recently had to replace the propane valve on our Dometic fridge. All went well but I mangled the latches getting the exterior door off. I thought, since they had a slot in their heads, that I needed to rotate them 90 degrees to open the door. They both broke when I did that.  Now, the door is being held shut with duct tape. Where can I get two more latches?
2 REPLIES 2
stevenal
Nomad II
Nomad II
Do they look like this?
Dometic 3101833P006
Spendy little things. Might want to shop a bit.
'18 Bigfoot 1500 Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
opnspaces
Navigator II
Navigator II
You're probably going to have to do some sleuthing to figure this one out. I would start with the Dometic website.
https://www.dometic.com/en-us/support/spare-parts
That will get you the make and model of the refrigerator plus links to suppliers. From a supplier website you might get lucky and then find part numbers. After you find the part numbers you can do some searches for the cheapest prices. I personally like Tweety's RV for parts.
