zaheer22
Sep 07, 2015Explorer
ELX-45 Main Breaker.
Hello,
Not sure if anyone has done this before, But I have a recently acquired 2007 Palomino thoroughbred that comes with a main 20 amp main breaker. Using electric heat and the Electric water heater has resulted in the breaker tripping every few hours ( as the Water heater cycles on). I was doing a little head scratching as I had 30 amp service. After some digging in the manual I discovered Palomino used a 20 AMP main breaker in the Elixir 45 amp converter. Now after even more research, I discovered the Elixir 45 amp manual calls for a 30 amp main. Not wanting to set anything on fire I pulled the converter and lo and behold the main incoming wire is sized for 30 AMP. Does anyone see any reason NOT to swap out the main to 30 amp?
