TurnThePage
May 01, 2014Explorer
Larryect wrote:The relay should go in the circuit to turn the blower on, not actually power it.
The problem I see with what you are suggesting is that relay is rated for 1.5 amps. I suspect the fan has a higher amperage. The relay would not last long before burning up if the fan draws more than 1.5 amps.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
