filthy_beast's avatar
filthy_beast
First mods to Wildcat
Cover to keep birds out of inbox
Safe in wardrobe
Moderator edit to re-size pictures to forum limit of 640px maximum size.
  • Aw man. When I saw the thread title, I thought someone was making an RV out of a Bowler Wildcat offroader. I can't do links from my IPad, but if you search Bowler Wildcat you'll find it. If you have Netflix, there are two Top Gear episodes featuring it.
  • Old-Biscuit wrote:
    NICE job on that pin box.
    Had to enclose the one on last 5'vr to keep the wasps from setting up home.
    Haven't needed to on this 5'vr cause we travel FT and rig doesn't sit long enough for any 'home building' plus I store umbilical cord inside pin box.
    That's a good safe. Where you able to bolt it 'thru' the floor?
    As your signature says "You cannot make things idiot proof, you can only make them idiot resistant"
    So true....very true :B
    Yes, it is screwed to the floor. I ripped down some 2x4 and countersunk screws through them into the floor. Added plywood screwed to them and the safe is bolted through the plywood.
  • NICE job on that pin box.
About DIY Maintenance
