BarneyS
May 08, 2019Explorer III
Forum Posting Problems
The RV.net portal to the Open Roads Forums has been having problems of late. Often, when trying to post or answer a Private Message or other action on the forum you will get a message that says something to the effect that the server is having problems.
This situation has been brought to the attention of the Admins and is currently being worked on. (I hope!)
The Trailer Life portal to the forums does not seem to be affected by this problem so I suggest you use it instead of RV.net for the time being until the problem is fixed. I cannot give you a timeline for when it will be done.
Barney
Barney
