- Ron3rdExplorer III
daveor wrote:
Ron3rd wrote:
Kenwood DDX 272, no need for bluetooth. All hooked up and updated today,, works fine.
What stereo unit did you go with?
Good choice and nice work! - daveorExplorer
DrewE wrote:
Thanks,, I added the door on the right side earlier, was just an open hole there,, I used Alder with a clear finish on it, no stain at all,, matches the original wood pretty good.
Very nice work! The wood filler panel you put in looks like it came from the factory. Much more in keeping with the cabinetry than some cheap plastic rectangle frame. - DrewEExplorer IIVery nice work! The wood filler panel you put in looks like it came from the factory. Much more in keeping with the cabinetry than some cheap plastic rectangle frame.
- daveorExplorer
What stereo unit did you go with? - Ron3rdExplorer IIIWhat stereo unit did you go with?
- GMandJMExplorerThat turned out well! Thanks for the photos.
- RbertalottoExplorerNicely done! I love a good modification!
- daveorExplorer
Dakota98 wrote:
had to edit the pic,, the wrong one loaded
Before & After ??? :B - Dakota98ExplorerBefore & After ??? :B
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
