newclassaguy's avatar
newclassaguy
HELP! diy project gone bad
Hi, Im new to this forum. I just inherited a 2006 damon challenger motorhome from my dad. I have been working to make it my own. But my biggest project so far has gone bad and I need help.
I replaced the carpet with vinyl plank flooring. It looks great, but when I bring the slideout in/out it is marking the new floor. I called a local rv dealer and he told me that i was stupid for removing the carpet and the only way to fix it was to pull the slide completely out of the coach and add rollers to the underside. He said it would cost around 2 thousand dollars.
I was sick to my stomach. I called a guy who does mobile rv repairs. He laughed and said the other guy was full of... He claimed that the slide was adjustable and he could fix it. He came out and adjusted on the slide. since my coach was not sitting level and the leveling jacks are also broken we couldnt really test it. The next day I moved the rv to a level spot and tested. He did not fix the issue. Now I have a grove in my brand new floor due to the head of a screw holding the trim on the slide out. I had him come back to see what happened and now he says I need to add rollers to the underside of the slide. He claims the rollers should be no more than $100 and it would take him 3 hrs ($300 labor). After already paying him $175 just to fiddle with the adjustments im worried about paying him more and still not having a solution.
I have been considering fixing it myself and I have 2 ideas, but need advise before starting.
Idea 1: Rollers. All the rollers I find are an inch or more in diameter and I worry that will be too much. I did find some rollers that are designed to be countersunk into the wooden floor of the slide. But i would need to raise the slide to get them installed.
Idea 2: glue carpet to underside of slide. my issue he is what type of glue would hold
I am completely open to suggestions and any advice is appreciated. I am supposed to go to the beach in september so im kinda in a rush to get it done.
Thanks.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
