HomeMade fridge screen
popeyemth
Too cheap to buy the outrageous priced commercial screening I made and installed some myself
The "slobber" tube for condensate/defrost goes through a 3/4 copper sweat union.
The next time I'm in town I'll replace that with a piece of PVC to make it invisible to the casual eye.
It's not very noticeable now
I used aluminum window screening held in place with two sided tape and overlapped with "Gorilla " duct tape.
What little loss of flow I get will be offset by two 120mm fans thermostat controlled.
Moderator edit to re-size pictures to forum limit of 640px maximum width.
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
21 REPLIES 21
camperpaul
John&Joey wrote:
2oldman wrote:
What's the mesh for on the outside, to the left of those 3 white things?
:h
Combustion Air intake and exhaust port for the furnace ...
... but there are a few water heater intake/exhaust combos that look like that.
Here is a link to a larger picture. If you click it you will see a huge photo and you can scroll down and right to read the label.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
John_Joey
:h
Thereโ€™s no fool, like an old fool.
John_Joey
Old Urban RV Myth:
Buy a cheap flea collar and cut it in half. Put a piece in the fridge compartment, and HW compartment to keep bugs out. Does it work, really don't know. Have I ever had bug issues after doing it...no.
tahiti16
Yup many of the class A's at least seem to like putting the furnace under the fridge including ours.
Ray, Cheryl & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
AlbertaNewbie
Terrydactile wrote:
Our furnace and intake/exhaust is under the fridge just like the OP's. It does come out from inside the rig.
Same here, hoping to do the screen mod this summer as well.
2014 Dutchmen 261bhs - 7200#'s loaded
2012 Ram 1500 SXT Crew Cab w/5.7L HEMI, 4x4 3.55 Gears
250w Conergy 250P 24v solar with tristar 45amp mppt charge controller
Terrydactile
Scott & Theresa Boyd
2 Daughters (Cassie & Brittany)
1 Furkid (Ella, a Basset Golden mix)
2008 Keystone Passport 280BH
2013 F 150 Supercrew EcoBoost XLT
popeyemth
I thought it was a strange place for a furnace too.
Old-Biscuit
2oldman wrote:
popeyemth wrote:
Yes that's the furnace with the silver mesh on the outside.
Ok. I have to admit that's the first time I've seen a furnace vent that appears to be nowhere near the furnace. And I've never seen a furnace under a refrigerator.
Looks like an Atwood 79/80 series exhaust/intake assembly.
They don't have an outside access panel. Remove furnace from inside rig.
Like some Suburbans but their exhaust/intake are vertical
2oldman
popeyemth wrote:
We are OVERRUN with paper wasps here-the aggressive ones not much better than hornets.
Hence the mesh.
Old-Biscuit
Thanks!!
Never had a problem inside the outside fridge compartment.
Wasps are fast builders and will defend their turf.
So I understand the reasoning.
popeyemth
They have even built a nest inside the gas door on the wife's car when we were driving it 6 days a week and getting gas regularly.
IF the screen gets dusty a paint brush will clean it or one could take the door off and hose it like a window screen.
What little air flow loss will be offset by thermostatically controlled exhaust fans.
Old-Biscuit
Why the screen on fridge vent cover?
And how do you keep t clean so it doesn't obstruct air flow?
eHoefler
I used fiberglass screen and urethane caulk. Just run a bead and push the screen into it, and let it cure.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
jake2250
That looks good! I did the same with plastic screening and used a hot glue gun. I like the slobber tubing,, going to have to reroute mine..
