time2roll
Jan 31, 2021Nomad
Q. which is most the power efficient 120V or 12V A. on paper the 12V is the most efficient @ 7.5A 90W, but it runs some slower than the 120V, so in the end they are practically the same. But if no inverter is on board then the 12V is still much faster than your gas/elect.
https://jc-refrigeration.com/product-information/
Unless you already have an inverter I am thinking I would go DC. Note a bit below you will need to upgrade the DC connection with possibly a relay interface between the control board and unit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
